Maca37 Offline
#1 Posted : Thursday, 10 September 2026 11:10:54 AM(UTC)
Maca37
Hi all
has anyone ever fitted the Lowe Fabrications HZ to VT commodore bolt on Booster and Master Cylinder upgrade?
Any recommendations on Mechanics in South East Melbourne who you could recommend to Install.Lowe fabrications Kit
Thanks All
Tony
#2 Posted : Thursday, 10 September 2026 8:39:52 PM(UTC)
I’d talk to whichever Engineer you’ll use to certify it first to make sure it can pass OK.
#3 Posted : Thursday, 10 September 2026 10:04:48 PM(UTC)
Originally Posted by: Maca37 Go to Quoted Post
Hi all
Thanks All
Tony
2 issues -
needs engineering certification if going on a HZ
and
will not fit HZs (or anything) with rear drum brakes if I read the Lowe website page correctly
Maca37 Offline
#4 Posted : Friday, 11 September 2026 7:57:19 AM(UTC)
Maca37
Thanks Smitty,I cant see where it says on the website it doesnt work with rear drums. I was thinking an djustable brake proportioning valve inline with the rear brake line to manually dial down the rear brake pressure might work
#5 Posted : Friday, 11 September 2026 8:23:30 AM(UTC)
I think the VT cylinder works OK on drums. Its what my HK has, it has BA-FG calipers and rotors on the front and standard HQ rear drum brakes. It uses a standard HG booster though, it is better than a VT one. Just has a cylinder adapter to make it work. Will be certified along with the rest of the car. Has to have braking tests done.
#6 Posted : Saturday, 12 September 2026 10:07:56 AM(UTC)
the VT master has the proportioning effect built into the cylinder, so it only works with rear disk brakes
#7 Posted : Saturday, 12 September 2026 10:20:40 AM(UTC)
I'm pretty sure they are OK with rear drums. I think Dr Terry told me this and also I think Peter from Hoppers. But as Maca says it may need further adjustment inline.
#8 Posted : Sunday, 13 September 2026 7:50:38 AM(UTC)
Holden show different part numbers for HZ/WB and Commodore VB-VP masters for disk brakes versus drum brake cars
and a number of A grade mechanics (inc my youngest brother) have told me you must use a master cylinder that matches the
cars braking system (hence my original comment)
Guest (8)
