dlm Offline
#1 Posted : Saturday, 28 November 2026 3:26:51 PM(UTC)
dlm
Can somebody please give me the exact measurement of the input shaft bearing retainer, from the rear face of the base to the end of the tube?
Thanks.
#2 Posted : Saturday, 28 November 2026 5:24:56 PM(UTC)
Was thanked: 40 time(s) in 39 post(s)
Thanks.
from the flat flange part that bolts to the gearbox case at the front to the tube end?
There are 2 different types (based around the front seal) but I think they are the same length
have several in the shed will measure this in the morning
dlm Offline
#3 Posted : Saturday, 28 November 2026 6:19:49 PM(UTC)
dlm
Yes. Thanks.
#4 Posted : Sunday, 29 November 2026 11:18:42 AM(UTC)
Thanks.
my steel rule says 124.5mm on one of the V8 M20s I measured and just on 125mm on the other M20 (and one of the M21s I have)
HTH
#5 Posted : Sunday, 29 November 2026 1:14:20 PM(UTC)
There are three different lengths in these and as Smitty says, two different seal types. I think that makes it 5 different types altogether:
6cyl slinger seal from the start of HK through to around 1973. First used on M15 3spd
6cyl neoprene seal, same length as above and started being used from the end of the above one through to the last Aussie 3spd or 4spd 6cyl which was probably WB in late 1984.
V8 with slinger seal, from the start of HT through to around 1973. First used on M15 V8 3spd.
V8 with neoprene seal, same length as earlier V8 one. Used from when the earlier V8 one ended until the last M21 4spd in VK Commodore.
4cyl LH. These used the 6cyl input shaft but a shorter cover (the shaft stuck out more). I think these were all neoprene seal.
