#1 Posted : Thursday, 3 February 2005 7:10:45 AM(UTC)
G`day All,
I put electronic ignition in my 202 red motor last weekend, and after the first tankful (its my work ute so it does a few miles)there is absolutely no difference either way in either performance or fuel economy- what gives? so many people said it would improve both or at least one, but its as though nothing has changed, have I done my dough and been conned here or what?
#2 Posted : Thursday, 3 February 2005 6:14:19 PM(UTC)
It should perform no better than the points ignition, if the points ignition is tuned perfectly. However it will stay consistent always, whereas points deteriorate over time (between tunes). It should also give you better spark, but make sure you have 12V
#3 Posted : Thursday, 3 February 2005 7:41:43 PM(UTC)
And also re-gap your points to 1.5mm, instead of 0.9mm. I noticed little difference until I did that.
You should also have a smoother accelleration curve, and less dead spots than on the points dizzy.
Jason.
#4 Posted : Thursday, 3 February 2005 8:01:33 PM(UTC)
Also, you will need to have the dizzy regraphed with the car on a dyno to acheive maximum benefit. Check that your vacuum advance can is working on the new dizzy.
Paul E
#5 Posted : Thursday, 3 February 2005 8:02:44 PM(UTC)
Paul E
#6 Posted : Thursday, 3 February 2005 8:36:44 PM(UTC)
That's something I"ve been considering anyway... any suggestions for somewhere that does a decent job of this in Western Suburbs of Brisbane?
Jason.
#7 Posted : Friday, 4 February 2005 2:03:19 AM(UTC)
Sorry Jason, wish I could help. Had the same problem finding somebody good in the western suburbs of Sydney, so I ended up having to regraph the thing myself. I could suggest a place or two in Victoria but as I have not used them myself (find out about th
#8 Posted : Friday, 4 February 2005 7:55:25 PM(UTC)
I have them on my old v8`s , I used to always have fuel deposits on my plugs (253) after changing to electronic they were much cleaner which would mean the fuel is buring up better plus extending the life of the plugs and no points to change , power diffe
