Rzeractor Offline
#1 Posted : Sunday, 7 June 2009 2:29:13 AM(UTC)
Rzeractor
As above, getting all the parts for a manual conversion.
Thanks =]
#2 Posted : Sunday, 7 June 2009 3:03:51 AM(UTC)
you wont need a pedal box, you will just need a clutch pedal and a brake pedal, just make sure you get the long bolt too
bundybluedog Offline
#3 Posted : Sunday, 7 June 2009 5:14:01 AM(UTC)
bundybluedog
i have a clutch pedal with the bolts and bits can post a pic as im pretty sure its HZ aslo have the rat trap to suit. brisbane but can post
#4 Posted : Sunday, 7 June 2009 5:18:55 AM(UTC)
Was thanked: 632 time(s) in 594 post(s)
Just be careful that there are two types in HZ: half and full cable. Half is the same as HX, Full is the same as WB.
With full cable there are 2 x types as well: 6cyl and V8.
HZute-efi-VS5L Offline
#5 Posted : Sunday, 7 June 2009 5:39:56 AM(UTC)
HZute-efi-VS5L
I have a wb full cable 6cyl setup if that interestes you. In SA
www.stickthisdecals.com.au
Rzeractor Offline
#6 Posted : Sunday, 7 June 2009 9:57:44 AM(UTC)
Rzeractor
@HK1837 - well its a 1979 HZ if that helps. Used to be manual originally >:(
Oh yeah its a 308 I forgot to mention
Rzeractor Offline
#7 Posted : Sunday, 7 June 2009 10:19:43 AM(UTC)
Rzeractor
Anyone mind posting what I need?
All I can think of are:
pedals
clutch
bellhousing
gearbox [t5]
clutch cable
rat trap(?)
crossmember
I think Ive missed a couple of things
#8 Posted : Sunday, 7 June 2009 6:11:51 PM(UTC)
bundybluedog
you forgot to mention you want a T5 so you wont need a rattrap. if its origanal engine and use to be manual will probably be holden paturn so a T5 will need a bellhousing conversion or redrill the engine block. supra 5 speed is just as good. you could pick up a M21 for a V8 including shifer and housing for about $250. let us know exactly what you want.
Dan
Rzeractor Offline
#9 Posted : Sunday, 7 June 2009 11:04:25 PM(UTC)
Rzeractor
Yeah Ive got a ford T5 box sitting here thats why I want to use that, and Ive heard from a few people that they line up almost perfect than a commodore t5 so I wont need to cut the trans tunnel or anything. The compliance plate says m21 so it was manual originally at one point. I bought it auto =[
