#1 Posted : Wednesday, 17 June 2009 6:05:13 AM(UTC)
Hi all is there any tricks to lineing up guards ,etc ,before paint.they are in primer now,any advice would be helpfull.
Jim in adelaide
MrPink Offline
#2 Posted : Wednesday, 17 June 2009 6:11:29 AM(UTC)
MrPink
There are body shims that alter the tilt of the front clip. This gets the gap from the front guard to the door aligned.
#3 Posted : Wednesday, 17 June 2009 6:19:04 AM(UTC)
where?
Jim in adelaide
#4 Posted : Wednesday, 17 June 2009 6:40:12 AM(UTC)
the two big bolts that hold your radiator support to your chassis rails, shims go between there to adjust
#5 Posted : Wednesday, 17 June 2009 7:24:19 AM(UTC)
Ah thats what they are for!I forgot about them!Thanxz everyone!
Jim in adelaide
Edited by user Wednesday, 17 June 2009 7:25:55 AM(UTC)  | Reason: Not specified
HQforme Offline
#6 Posted : Thursday, 18 June 2009 5:08:13 AM(UTC)
HQforme
I was amazed at how well everything lined up when i put my front end on. Even with two new panels mixed with two old ones. Theres movement in the body holes so you can align seams and edges. I measured from a level surface to points on the radiator support to get that level, and then after bolting the panels up loosely, measured again. As i went i compared panel gaps to what my measurements told me was straight. On anything less than a "perfect" car there will probably be a little compromise here.
"Silly modern cars"
