Fastlane
Holden Forums
Holden General Discussion
lineing up guards ,etc ,before paint?help?
Joined: 28/03/2008(UTC) Views messages in topic : 1,903
Hi all is there any tricks to lineing up guards ,etc ,before paint.they are in primer now,any advice would be helpfull.
Jim in adelaide |
Jim in Adelaide.. |
There are body shims that alter the tilt of the front clip. This gets the gap from the front guard to the door aligned.
Jim in Adelaide.. |
the two big bolts that hold your radiator support to your chassis rails, shims go between there to adjust
Ah thats what they are for!I forgot about them!Thanxz everyone! Jim in adelaide Edited by user Wednesday, 17 June 2009 7:25:55 AM(UTC)
| Reason: Not specified |
Jim in Adelaide.. |
I was amazed at how well everything lined up when i put my front end on. Even with two new panels mixed with two old ones. Theres movement in the body holes so you can align seams and edges. I measured from a level surface to points on the radiator support to get that level, and then after bolting the panels up loosely, measured again. As i went i compared panel gaps to what my measurements told me was straight. On anything less than a "perfect" car there will probably be a little compromise here. |
"Silly modern cars" |
Fastlane
Holden Forums
