Keeo Offline
#1 Posted : Tuesday, 9 March 2010 4:19:41 AM(UTC)
Keeo
Is it possible to change camshaft without removing the motor ? Its hkhthg model and smallblock chevy .-keeo cheers
#2 Posted : Tuesday, 9 March 2010 4:50:51 AM(UTC)
Easy. Just pull the radiator out.
adam PERTH Offline
#3 Posted : Tuesday, 9 March 2010 4:56:05 AM(UTC)
adam PERTH
chevy V8 easier than holden V8.
watch your cam bearings!
WANTED:
-2 14 x 9.25 CSA style Centrelines.
-2 x 15 x 8 Dragway centrelines
Keeo Offline
#4 Posted : Tuesday, 9 March 2010 5:14:58 AM(UTC)
Keeo
Unreal, thats just want i wanted to hear. thanks-keeo
#5 Posted : Wednesday, 10 March 2010 1:58:52 AM(UTC)
inlet manifold,carby,water pump,timing cover radiator,lifters ,pushrods,tappets..?
Edited by user Wednesday, 10 March 2010 2:00:26 AM(UTC)  | Reason: Not specified
#6 Posted : Wednesday, 10 March 2010 2:04:36 AM(UTC)
What makes a Chev cam change easier than a Holden V8 ? I find the Chev timing cover to be a mongrel job with the sump still in place.
The best argument against democracy is a 5 minute conversation with the average voter.
#7 Posted : Wednesday, 10 March 2010 2:51:50 AM(UTC)
yeah. thats got me stumped too?
adam PERTH Offline
#8 Posted : Wednesday, 10 March 2010 9:29:57 AM(UTC)
adam PERTH
i normally back the sump bolts off a bit especially toward the front on a chev to get that timing cover lip in.
what is easier??
water pump (less bolts, of same length, and bolts that will actually take thread)
inlet manifold (chev, ford , anything is easier to seal than a corroded holden v8)
timing cover - as above, no warping or corrosion with chev
chev fuel pump on block, holden V8 on timing cover.
Holden single row timing chain??, - well that will need replacing.
whats the date casting on that holden V8 anyway?? - Dunno, i cant see it because of all the silastik.
WANTED:
Edited by user Wednesday, 10 March 2010 11:22:35 AM(UTC)  | Reason: Not specified
