iuiw Offline
#1 Posted : Monday, 24 January 2011 6:08:32 AM(UTC)
iuiw
What parts and labour are required to change a LJ front end to a LC front end.
#2 Posted : Monday, 24 January 2011 5:44:43 PM(UTC)
When you say 'front end', do you mean front suspension or front panels ?
iuiw Offline
#3 Posted : Tuesday, 25 January 2011 4:21:24 AM(UTC)
iuiw
Sorry, I mean the front nosecone/area. So I can put a LC grille on the front end,
David Offline
#4 Posted : Wednesday, 26 January 2011 7:30:29 PM(UTC)
David
Years ago, after a minor ding, I had an LJ nose cone fitted to an LC so I could fit the LJ grill (I thought then that LJ looked better). The grill went on easily. But then I found that the LJ headlight surrounds would not fit to the LC mudguards. I was not prepared to fit LJ guards, or to modify the LC guards (Would have probably needed bog and repaint). Therefore I ground off the vertical pillars beside the headlights and re-fitted the LC grill and headlight surrounds.
My opinion: Don't do it. I now think LC grill looks better anyway. If you do, I suggest you also change the rear lights - the car will look a bit silly with LJ front and LC rear.
David
