eskimo_joe777 Offline
#1 Posted : Tuesday, 29 March 2005 7:12:21 AM(UTC)
eskimo_joe777
I have 2* 253 and am makin 1 good engine out of both and was wondering if the valves out of the blue motors head will go into the red motor?
i will be doing a seat grind and valve grind but will it fit straight in after that?
Cheers Justin
#2 Posted : Tuesday, 29 March 2005 10:05:06 AM(UTC)
Remember there a non-pollution and pollution heads in the red area. Blues should be all pollution heads. Valves should be same across the board. Well in HQ & LH/LX they were. Why not get new seats and guides and go for slighty bigger valves with ULP safet
#3 Posted : Tuesday, 29 March 2005 7:42:15 PM(UTC)
Have to disagree. You should never fit bigger valves to a 253. The valves are sized to suit a 308, and even a very lumpy 253 won't need as much flow as a stock 308. All you will achieve is a loss of torque.
#4 Posted : Wednesday, 30 March 2005 5:11:28 AM(UTC)
Bigger valves in a 253 can also foul on the cylinder walls & require reliefs which lowers compression - a backward step!
#5 Posted : Wednesday, 30 March 2005 5:26:24 AM(UTC)
eskimo_joe777
thanks for the info it was helpful but i was also wondering if any1 knew the valve grind angle for the valve and the seat for a 253 out of a HJ because i thought i would clean them up and give them a grind before i put the engine back together.
cheers Ju
#6 Posted : Wednesday, 30 March 2005 5:32:15 AM(UTC)
valve face angle 45deg
seat faces in head 46deg
#7 Posted : Wednesday, 30 March 2005 8:43:32 AM(UTC)
Disagree on the above ! If 253's cant take bigger valves why did Yella Terra make a GAS head for a 253/308 RED ? It has larger valves than bog standard, and its says THEY DO NOT FOUL the cylinder walls or pistons. Obviously a STAGE III racing type would b
#8 Posted : Wednesday, 30 March 2005 10:17:29 AM(UTC)
The gas heads are fine because they have the small 1.810 valves. The larger valves are 1.94 and as mentioned can cause fouling problems in the 253.
This page was generated in 0.065 seconds.
