eskimo_joe777 Offline
#1 Posted : Tuesday, 29 March 2005 7:12:21 AM(UTC)
eskimo_joe777
I have 2* 253 and am makin 1 good engine out of both and was wondering if the valves out of the blue motors head will go into the red motor?
i will be doing a seat grind and valve grind but will it fit straight in after that?
Cheers Justin
#2 Posted : Tuesday, 29 March 2005 10:05:06 AM(UTC)
Remember there a non-pollution and pollution heads in the red area. Blues should be all pollution heads. Valves should be same across the board. Well in HQ & LH/LX they were. Why not get new seats and guides and go for slighty bigger valves with ULP safet
#3 Posted : Tuesday, 29 March 2005 7:42:15 PM(UTC)
Have to disagree. You should never fit bigger valves to a 253. The valves are sized to suit a 308, and even a very lumpy 253 won't need as much flow as a stock 308. All you will achieve is a loss of torque.
#4 Posted : Wednesday, 30 March 2005 5:11:28 AM(UTC)
Bigger valves in a 253 can also foul on the cylinder walls & require reliefs which lowers compression - a backward step!
#5 Posted : Wednesday, 30 March 2005 5:26:24 AM(UTC)
eskimo_joe777
thanks for the info it was helpful but i was also wondering if any1 knew the valve grind angle for the valve and the seat for a 253 out of a HJ because i thought i would clean them up and give them a grind before i put the engine back together.
cheers Ju
#6 Posted : Wednesday, 30 March 2005 5:32:15 AM(UTC)
valve face angle 45deg
seat faces in head 46deg
#7 Posted : Wednesday, 30 March 2005 8:43:32 AM(UTC)
Disagree on the above ! If 253's cant take bigger valves why did Yella Terra make a GAS head for a 253/308 RED ? It has larger valves than bog standard, and its says THEY DO NOT FOUL the cylinder walls or pistons. Obviously a STAGE III racing type would b
#8 Posted : Wednesday, 30 March 2005 10:17:29 AM(UTC)
The gas heads are fine because they have the small 1.810 valves. The larger valves are 1.94 and as mentioned can cause fouling problems in the 253.
