OldDog Offline
#1 Posted : Tuesday, 15 March 2011 5:34:02 AM(UTC)
OldDog
Howdy all, just a quick question, is the radiator support panel on the WB statesman the same as the panel on the standard ute?
Bill
#2 Posted : Tuesday, 15 March 2011 6:35:30 AM(UTC)
Yeah, think there is no difference.
tunnamark Offline
#3 Posted : Tuesday, 15 March 2011 6:54:36 AM(UTC)
tunnamark
They are different but you can cut and modify the standard one to suit the statesman lights, I think you also have to make brackets to hold the bumperettes
Mark
OldDog Offline
#4 Posted : Tuesday, 15 March 2011 7:09:04 AM(UTC)
OldDog
Thanks for that. Luckily the donor ute for the project has the right radiator panel, i'm just trying to get as much work done on the new body as i can before i go to pick it up.
Heres a link to the thread i started on justcommodores about the project http://forums.justcommod...te-called-mrs-marsh.html
(Not sure where to start a build thread here)
#5 Posted : Tuesday, 15 March 2011 7:31:55 AM(UTC)
You just have to replace the uprights that hold the grille with Statesman ones. Not a 5 minute job, but can be done with a bit of hard work.
adam PERTH Offline
#6 Posted : Tuesday, 15 March 2011 9:00:23 AM(UTC)
adam PERTH
when you say standard ute, r u refering to round headlight WB or Square headlight WB??
#7 Posted : Tuesday, 15 March 2011 7:58:42 PM(UTC)
I don't think it matters from memory Adam, you just remove the round headlight mounts off the support to turn it into a square headlight one.
OldDog Offline
#8 Posted : Wednesday, 16 March 2011 4:57:25 AM(UTC)
OldDog
Square headlight it is. I've found a few pics of panels on ebay and compared em to the one i have here and they are different, just like you guys said!
Thanks for the replies, this has gotta be one of the fastest response websites i've ever been part of and your help is appreciated!
Bill
