deputy Offline
#1 Posted : Saturday, 26 March 2011 1:47:22 AM(UTC)
deputy
Hi there.
Does anyone know what the chances (if any) of fitting a GTS steering wheel from a LJ/HQ-HZ to a HR? If so what needs to be modified so it works? I want a larger but sport type wheel for it. Any help apprciated. Anthony
#2 Posted : Saturday, 26 March 2011 5:07:46 AM(UTC)
HK/T/G and LC sports steering wheel will fit, HQ/LJ style will not fit, as the spline is different.
Warren
VANOM Offline
#3 Posted : Sunday, 27 March 2011 4:21:02 AM(UTC)
VANOM
I had a HKTG GTS boss that had been tapered on the inside diameter on the coloum side so it would fit a HR. So with a little bit of modifying they will fit and no need to pay an arm and a leg for a genuine wheel as you can just buy one of the reproduction type that are available which also saves on the pain knowing that you will not be modifying a genuine wheel.
Utility8 Offline
#4 Posted : Monday, 28 March 2011 8:03:29 PM(UTC)
Utility8
As VANOM says, it is possible. As described above for HK/T/G LC factory sports wheels using an original Monaro/Torana boss. Another way around it is to use an aftermarket boss & machine to suit.
Below is a Monaro boss on EH/HR column.
Clearance of outer shroud, indicator assembly, indicator return pins & horn contact design need to be addressed. But, it can work if you're prepared to sacrifice a genuine boss to the lathe. Just think it through.
Conversely, this is a modified SAAS boss.
And the end result. Although not the Monaro/Torana horn assembly, it is just a matter of thinking through the clearances & making it work.
utility8
deputy Offline
#5 Posted : Monday, 28 March 2011 11:23:57 PM(UTC)
deputy
Thank you all. I will look into the LC option 1st
Premier 350 Offline
#6 Posted : Thursday, 31 March 2011 10:12:20 PM(UTC)
Premier 350
That wheel looks perfect-like a factory fit.
And is that a Trimatic auto quadrant I see?
Utility8 Offline
#7 Posted : Friday, 1 April 2011 5:01:07 AM(UTC)
Utility8
Thanks Prem350 & yes, it certainly is a Trimatic indicator quadrant.
utility8
#8 Posted : Friday, 1 April 2011 5:16:26 AM(UTC)
Utility8....Awesome looking stuff!!
Utility8 Offline
#9 Posted : Saturday, 2 April 2011 9:04:10 AM(UTC)
Utility8
Gee thanks Jimbo.
I wanted the early era feel without the fat leather wheel.
utility8
Motorsportlady Offline
#10 Posted : Sunday, 20 July 2014 1:17:35 AM(UTC)
Motorsportlady
Just looking at what you have posted, you have pictured a black wheel above and you have a red wheel in your avatar, are these wheels 69 Corvette wheels or grant wheels both with a shallower dish than a HKTG wheel?
Edited by user Sunday, 20 July 2014 1:21:45 AM(UTC)  | Reason: Not specified
Utility8 Offline
#11 Posted : Tuesday, 22 July 2014 4:51:16 AM(UTC)
Utility8
They are both Corvette wheels and quite shallow adapted to suit on the old SAAS boss. Needed the arm room.
utility8
This page was generated in 0.122 seconds.
