fitzsi Offline
#1 Posted : Saturday, 26 March 2011 11:45:48 PM(UTC)
fitzsi
Can anyone give any solutions for removing a roll master crank shaft gear as the previous engine builder has installed it incorrectly.
we have tried using a puller as it has bolt holes either side of the pulley but we hav'nt been able to remove it with the pullers as I'm a bit concerned about the bolts snapping
greenhj Offline
#2 Posted : Sunday, 27 March 2011 12:36:32 AM(UTC)
greenhj
put a bit of tension on it with the puller and using an lpg torch add a bit of heat around the crank gear.
With the tension from the puller, as soon as its ready it will "pop" and hopefully come off all the way.
