Hi Guys,
Looking for the final piece of my puzzle. I got a v8 yoke to put on my 6cyl banjo. Turns out it does not fit (bummer) Any way.
If anyone has a v8 banjo centre or even a complete diff for a HK i would be happy to buy it off you ASAP.
I am located in Werribee VIC 0418114706
quote: Originally posted by roadster
Hi Guys,
i have a coupla single spinners, 336 & 308s, & a complete 278LSD drum to drum . if interested 0412109239 www.bellarineclassicautos.com.au
The only difference between a V8 and a 6cyl banjo diff centre is the yoke. So if the V8 yoke you have does not fit your banjo centre I would suspect that it is a Salisbury or 10 bolt yoke not a banjo one. Cheers Paul. Edited by user Monday, 4 April 2011 7:28:34 PM(UTC)
| Reason: Not specified
Thats what i thought about the yokes. Maybee i will take it back amd get him to recheck. Thanks
Joined: 16/09/2010(UTC) Posts: 411  Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
A V8 Banjo diff centre has two long bolts attaching it to the housing. 6 cylinder bolts are all same length. |
The HKTG Garage. The Home of HK HT HG Holden. |
only 3.08 or 2.78 banjos have two long bolts on the bottom and they can be 6cyl or v8 the only differences is the yoke |
OLD HOLDENS NEVER DIE |
I agree with this as well. Cheers Paul.
FYI every 3.08 & 2.78 banjo diff had th 2 long bolts on bottom (one being drain plug)regardless of whether it be in a 6cyl or V8. Every 3.36, 3.55 etc were all short bolts in 6cyl or V8. They were all made for 6cyl then holden just whacked a bigger yolk on em to suit V8 t/shaft !!!! I HOPE THIS CLEARS UP ANY WRONG INFO THATS BEEN LISTED regards dave www.bellarineclassicautos.com.au
Also another addition, all HK 6cyl 3.08 banjo centres had V8 yokes. |
Thanks for the info guys, took the Yoke back and now have the correct v8 yoke. And YES as stated it fitted this time so all is good.
Thanks heaps for the info
