roadster Offline
#1 Posted : Sunday, 3 April 2011 5:35:58 AM(UTC)
roadster
Hi Guys,
Looking for the final piece of my puzzle. I got a v8 yoke to put on my 6cyl banjo. Turns out it does not fit (bummer) Any way.
If anyone has a v8 banjo centre or even a complete diff for a HK i would be happy to buy it off you ASAP.
I am located in Werribee VIC
0418114706
dirty davo Offline
#2 Posted : Monday, 4 April 2011 6:15:15 PM(UTC)
dirty davo
Originally posted by roadster
Hi Guys,
0418114706
i have a coupla single spinners, 336 & 308s, & a complete 278LSD drum to drum . if interested 0412109239
#3 Posted : Monday, 4 April 2011 7:27:59 PM(UTC)
The only difference between a V8 and a 6cyl banjo diff centre is the yoke.
So if the V8 yoke you have does not fit your banjo centre I would suspect that it is a
Salisbury or 10 bolt yoke not a banjo one.
Cheers Paul.
Edited by user Monday, 4 April 2011 7:28:34 PM(UTC)  | Reason: Not specified
roadster Offline
#4 Posted : Tuesday, 5 April 2011 10:32:05 AM(UTC)
roadster
Thats what i thought about the yokes. Maybee i will take it back amd get him to recheck. Thanks
The HKTG Garage Offline
#5 Posted : Wednesday, 6 April 2011 3:45:13 AM(UTC)
The HKTG Garage
Cheers Paul.
A V8 Banjo diff centre has two long bolts attaching it to the housing. 6 cylinder bolts are all same length.
holdenhqprem Offline
#6 Posted : Wednesday, 6 April 2011 5:50:57 AM(UTC)
holdenhqprem
only 3.08 or 2.78 banjos have two long bolts on the bottom and they can be 6cyl or v8 the only differences is the yoke
OLD HOLDENS NEVER DIE
#7 Posted : Wednesday, 6 April 2011 7:09:15 AM(UTC)
I agree with this as well.
Cheers Paul.
dirty davo Offline
#8 Posted : Saturday, 9 April 2011 12:27:26 AM(UTC)
dirty davo
Cheers Paul.
FYI every 3.08 & 2.78 banjo diff had th 2 long bolts on bottom (one being drain plug)regardless of whether it be in a 6cyl or V8.
Every 3.36, 3.55 etc were all short bolts in 6cyl or V8.
They were all made for 6cyl then holden just whacked a bigger yolk on em to suit V8 t/shaft !!!!
I HOPE THIS CLEARS UP ANY WRONG INFO THATS BEEN LISTED
regards dave
#9 Posted : Saturday, 9 April 2011 2:19:14 AM(UTC)
Also another addition, all HK 6cyl 3.08 banjo centres had V8 yokes.
roadster Offline
#10 Posted : Sunday, 10 April 2011 11:04:46 PM(UTC)
roadster
Thanks for the info guys, took the Yoke back and now have the correct v8 yoke. And YES as stated it fitted this time so all is good.
Thanks heaps for the info
