hjprem Offline
#1 Posted : Monday, 4 April 2011 11:15:36 PM(UTC)
hjprem
On the weekend I removed the sill trims off my dads HJ premier and got the shock of my life, massive rust holes on both outer sides.
I have since googled sill panels and found many available by different places.
Just wanted to know what was recommended and the experience people have had.
Is this something I can attempt myself, or is there someone in sydney recommended who does this rust repair?
Edited by user Monday, 4 April 2011 11:21:59 PM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, 5 April 2011 3:59:18 AM(UTC)
I'd get someone to do it for you. No big drama, and not all that hard for someone with all the equipment. hey have rusted from the outside in so most of it will be OK. Make sure you mark where the tabs go so you can get them put back on for the moulds.
hjprem Offline
#3 Posted : Tuesday, 5 April 2011 4:50:09 AM(UTC)
hjprem
Will the sills from rare spares do the job?
And how do you put the tabs back on?
#4 Posted : Tuesday, 5 April 2011 4:57:45 AM(UTC)
Yes They will do (rare spares)and just mark the new sill the same as the old one with a texta
#5 Posted : Tuesday, 5 April 2011 5:57:30 AM(UTC)
Tabs are put on by a panel beater. They use them for an easybeat (I think that is what it is called). You can also use special rivets.
#6 Posted : Tuesday, 5 April 2011 6:16:39 AM(UTC)
similar to the top door chrome kits??
hjprem Offline
#7 Posted : Tuesday, 5 April 2011 7:13:03 PM(UTC)
hjprem
Can you please tell me what the difference is between the two sills available for HJ premier?
http://www.rarespares.net.au/ho...c&pno=0&description=sill
RP102T and 2809814
BIGCAV Offline
#8 Posted : Tuesday, 5 April 2011 7:52:29 PM(UTC)
BIGCAV
a hj prem takes a 2809813 and 2809814
im reworking all the descriptions now
hjprem Offline
#9 Posted : Tuesday, 5 April 2011 8:00:16 PM(UTC)
hjprem
BIGCAV it was the RP102T that I was comparing, that too say's HQ-WB outer sill
hjprem Offline
#10 Posted : Tuesday, 5 April 2011 8:10:42 PM(UTC)
hjprem
is there anyone in sydney who does this rust repair work?
I wonder if there is a mobile rust repairer?
#11 Posted : Tuesday, 5 April 2011 9:04:48 PM(UTC)
Yes, that listing is very confusing. Maybe the RP102T is the longer (wagon, ute, van, Statesman) type & the 2809814 is the shorter (sedan/coupe) type.
BIGCAV Offline
#12 Posted : Tuesday, 5 April 2011 9:22:22 PM(UTC)
BIGCAV
according to the catalogue there is 4 numbers
2816448/9 suits 1 tonne (shorter obviously)
2809813/4 sedan
2809817/8 coupe
2809815/6 wagon/statesman/pv/ute
we know the 2809813/4 is correct for sedan and we have a guy going out today to compare the rp102t and 2809813 to both a coupe and the other models, im surprised a coupe sill wasnt the same as a sedan? but we should have the correct descriptions this afternoon
#13 Posted : Tuesday, 5 April 2011 10:37:49 PM(UTC)
The coupe will be different to the sedan where the door openings & pillars are located. It depends how 'complete' the replacement panel is. For rust repair purposes it may not need to go as far up as the door openings.
BIGCAV Offline
#14 Posted : Tuesday, 5 April 2011 11:30:30 PM(UTC)
BIGCAV
thats what i guessed it would be. an original panel goes right to the top while a replacement is just a repair section of that panel
my issue with that theory is that if its only the top b pillar section that is different why is a wagon/statesman sill the same part number as a ute?
no point theorising it though, were going to 100% certain before i muck around with it
hjprem Offline
#15 Posted : Tuesday, 5 April 2011 11:53:55 PM(UTC)
hjprem
I'll take some photos and post them tonight, it might help decide what I need.
#16 Posted : Wednesday, 6 April 2011 3:31:30 AM(UTC)
One will just be a rust repair section, the other a whole sill.
hjprem Offline
#17 Posted : Wednesday, 6 April 2011 7:59:33 AM(UTC)
hjprem
here are some photos
Is the difference a section or the whole sill and which do I need?
Edited by user Thursday, 7 April 2011 12:09:35 AM(UTC)  | Reason: Not specified
#18 Posted : Thursday, 7 April 2011 3:15:49 AM(UTC)
I'd say just the folded up rust repair section.
#19 Posted : Thursday, 7 April 2011 3:56:02 AM(UTC)
And plenty of rust converter.
hjprem Offline
#20 Posted : Thursday, 7 April 2011 9:20:36 PM(UTC)
hjprem
Jim,
Do you apply the rust converter, in the sill panel area and leave it before replacing the new outer sill or does it require anything else like a por15 before sealing it up?
