The HKTG Garage Offline
#1 Posted : Saturday, 23 April 2011 7:06:43 AM(UTC)
The HKTG Garage
I was wondering if anyone has a photo or pic of the trim rings listed in the HK Parts Catalogue M36640 (yellow cover)on page 28 in the Accessories section. Part number 7428015 with 14-5/8" Outside Diameter. Ta.
Edited by user Saturday, 23 April 2011 7:08:15 AM(UTC)  | Reason: Not specified
blameyone Offline
#2 Posted : Sunday, 24 April 2011 7:50:49 AM(UTC)
blameyone
Hi Simon, Are they the light ones that are held on by the hub cap ? I thought I had one here but I've just been out to the shed and no I can't it. If I can dig it up you're welcome to a photo. The other 15 & 1/4 inch ones are made to clip to the standard hub cap....Jack
#3 Posted : Sunday, 24 April 2011 7:59:54 PM(UTC)
The HKTG Garage
Hi Jack, I believe the 15-1/4" Outside Diameter ones listed are the more commonly seen version held on by the hubcap. They are chrome steel with lots of small squares, same as the HR type. I have several sets of these. They were copied in a lighter aluminium and sold as an aftermarket non genuine accessory, often passed off on ebay as "Original Nasco".
The outer ring attached to a Premier hubcap was not sold seperately as far as I know. You just bought the whole thing as a replacement (also an accessory on Kingswood/Belmont/Monaro).
The reason for the post is that there are 3 accessory types listed in the HK Parts Catalogue M36640 (yellow cover) but 7428015 is not listed in the updated blue cover HK parts catalogue, or the HT HG ones. I'm just curious to see the mystery ones.
Squeak327 Offline
#4 Posted : Monday, 2 May 2011 8:53:22 AM(UTC)
Squeak327
#5 Posted : Monday, 2 May 2011 9:13:22 AM(UTC)
The HKTG Garage
Hi Squeak,
No they are the most common type, the ones I mentioned above that were replicated in a cheap flimsy alloy. They are the 15"1/4 OD ones.
Thanks for looking out though.
blameyone Offline
#6 Posted : Tuesday, 10 May 2011 7:21:32 AM(UTC)
blameyone
Hi Simon. is this what you were looking for ? E-bay item#290563915754....Jack
#7 Posted : Tuesday, 10 May 2011 8:45:13 AM(UTC)
The HKTG Garage
No Jack, they are 7437525, the 15 1/4" OD type. The most common ones. Thanks anyway.
#8 Posted : Sunday, 7 April 2013 9:46:34 AM(UTC)
The HKTG Garage
craigh Offline
#9 Posted : Sunday, 7 April 2013 7:33:16 PM(UTC)
craigh
Has 'made in NZ' on label....should make them the NZ version made by the Dawson Reed company in Wainoni Road, Christchurch. The Factory (& company) are long gone. They made lots of auto accessories eg trims, mirrors etc for many years when most of the maunfacturers were local assembly. Holden NZ used to do that - use local manufacturers & use genuine part number.
This page was generated in 0.088 seconds.
