ht307munro Offline
#1 Posted : Tuesday, 1 November 2011 6:05:10 AM(UTC)
ht307munro
I have a full length auto console for a a HT but it does not have a small "hump" on the passenger side. I will be running a powerglide / 307 combo in the car. Can anyone please advise if I need one with the "hump" and if so what would my console be for? It has the auto insert. Cheers.
Alex
#2 Posted : Tuesday, 1 November 2011 7:38:38 AM(UTC)
The hump is to clear the shifter. You can break the piece out and fit a hump from a damaged console, see inside of console for cut out indicator.
Consoles without the hump are for opel 4 speed.
Warren
ht307munro Offline
#3 Posted : Tuesday, 1 November 2011 7:55:42 AM(UTC)
ht307munro
Warren thanks for that. How would you recommend breaking the piece out (besides carefully)? How is the hump fitted - glued in?
Alex
Mr Bob Dobalina Offline
#4 Posted : Tuesday, 1 November 2011 10:47:19 AM(UTC)
Mr Bob Dobalina
cut out with dremel or similar. originally is welded (heat pressed) but you can just glue in, has a flange around it to sit inside the cutout
dirty davo Offline
#5 Posted : Friday, 4 November 2011 7:53:06 AM(UTC)
dirty davo
all auto consoles need this hump to clear linkages & also saginaw!!
only one that doesnt need it is exclusive to opel box..
i have some 'humps' available if anyone interested, or send your console to me & ill supply & fit it for you
can email pics if interested '[email protected]'
0412109239 0352 488055
