I have a full length auto console for a a HT but it does not have a small "hump" on the passenger side. I will be running a powerglide / 307 combo in the car. Can anyone please advise if I need one with the "hump" and if so what would my console be for? It has the auto insert. Cheers. |
Alex |
The hump is to clear the shifter. You can break the piece out and fit a hump from a damaged console, see inside of console for cut out indicator.
Consoles without the hump are for opel 4 speed.
Warren
Warren thanks for that. How would you recommend breaking the piece out (besides carefully)? How is the hump fitted - glued in? |
Alex |
cut out with dremel or similar. originally is welded (heat pressed) but you can just glue in, has a flange around it to sit inside the cutout
all auto consoles need this hump to clear linkages & also saginaw!! only one that doesnt need it is exclusive to opel box.. i have some 'humps' available if anyone interested, or send your console to me & ill supply & fit it for you can email pics if interested ' [email protected]' 0412109239 0352 488055 www.bellarineclassicautos.com.au
