domc Offline
#1 Posted : Friday, 16 December 2011 7:05:50 AM(UTC)
domc
Hi can someone help with what wattage sealed beam headlights I need for the twin headlight HQ - high/low beam? Im talking about the old Lucas ones, part numbers would be helpful too!
domc Offline
#2 Posted : Wednesday, 21 December 2011 9:59:38 PM(UTC)
domc
Surely there's some HQ experts out there who can help??
#3 Posted : Wednesday, 21 December 2011 11:23:56 PM(UTC)
There were various wattages used over the years, but they only vary 5 or 10 watts so it's immaterial. The twin headlight units for those models were all 5.75-inch diameter.
The most common ones that I remember were the outer hi/low beams at 50/37.5W or 60/40W & the inner hi beams at 60W or 65W.
As I said, the wattage is not critical as long as LH & RH are the same & the lo beams suit RH drive.
The quality ones were made by Guide, Lucas, Koito & Stanley, (GM-H used Guide & Lucas at the factory) most of these are no longer, & the only ones left on the market are no-name Asian units, so NOS or 2nd hand is the way to go.
domc Offline
#4 Posted : Monday, 20 August 2012 7:30:46 AM(UTC)
domc
sorry to rehash an old thread......
what is the difference between the 3 pin 37.5/50W or the 2 pin 50W lights. I have both of these in the Lucas brand...do they both fit my HQ twin front?
#5 Posted : Monday, 20 August 2012 7:34:42 AM(UTC)
The 3-pin ones are the outer hi-lo beam units & the 2-pin ones are the inner (hi-beam only) units.
domc Offline
#6 Posted : Monday, 20 August 2012 8:19:58 AM(UTC)
domc
so...when the normal headlights are on the outer lights are at 37.5W are on and when the high beams are switched on they both light up at 50W???
Premier 350 Offline
#7 Posted : Wednesday, 22 August 2012 2:11:03 AM(UTC)
Premier 350
On the high beam side, what about some USA repro sealed beams ?
I'm sure I've seen new repro Guide ones on US websites.
What do restorers in the UK use for restorations- maybe there's some decent ones available in the UK.
I think the USA high beams would work in Aus - but not sure.
The low beams no.
Other than that, I'm stumped.
