wiggerv8 Offline
#1 Posted : Saturday, 21 January 2012 10:12:38 AM(UTC)
wiggerv8
hi guys im in the middle of a injected 5.0 conversion to my zl fairlane i have changed the whole wiring loom in the whole car eb dash is in also all is in working order dash windows ecc i need help with the gearbox mount ,ac,engine mounts and left hand side header has any one done this conversion if so a little help would be great cheers
aaron
#2 Posted : Saturday, 21 January 2012 10:34:59 AM(UTC)
OK when I converted Dads old XF from an auto to a T5 I needed a completely different gearbox cross member for the T5 as the T5's mount was about 2 inches lower and about 2 inches further back than the normal XF mount.
So it might be an idea to have a look at the gearbox mount on a 6 cylinder auto XG ute or van as I believe that they still have the XF floor. Maybe even an XH but I think that they have an E series floor.
As for engine mounts you simply use the bolt on brackets from any V8 XA - XE and the mounting rubbers from any V8 XR - XE Windsor or Cleveland they are the same and will bolt directly up to your 5.0 block.
I'm doing a 5.0 into a Capri and I intend to use early 302W extractors with bosses welded in for the oxygen sensors and flanges for the cats so you might get away with XR, XT, XW XY 302W extractors.
Sorry I can't offer much about the A/C you may have to get pipes custom made to connect the ZL A/C to the E series compressor.
BIGCAV Offline
#3 Posted : Saturday, 21 January 2012 11:34:52 AM(UTC)
BIGCAV
My only 5l conversion was with an auto au motor into an xg, auto didn't need any mods so I guess just get an xg cross member, engine mounts were as per above, exhaust was stubby mustang headers with custom lower pipes but e series are easier I believe due to the starter motor being on different sides, au ac never fitted because it fouled on the body
#4 Posted : Saturday, 21 January 2012 10:49:35 PM(UTC)
Was the XG cross member kind of horse shoe shaped and did it look like it would bolt up under an XD XE or XF?
I'm just trying to satisfy my own curiosity here that's all as I have never looked under an XG.
BIGCAV Offline
#5 Posted : Sunday, 22 January 2012 3:54:42 AM(UTC)
BIGCAV
honestly i cant remember mate, we only did it on stands and slid the motor in from the bay with the tranny and found it bolted in ok so spent a total of 2 minutes looking at it
wiggerv8 Offline
#6 Posted : Tuesday, 24 January 2012 7:17:51 AM(UTC)
wiggerv8
thanks allot guys jim5.0 i know what you are talking about with the cross member i went looking for one at the wreckers cause i have seen one before i did have one my self used it on a mates car with his conversion now i need one and bigcav yeah i tried some mustang extractors and yeah the left side was hitting the starter motor so what did you do with yours and the ac hits the strut tower so what did you do about that one allso and cheers again
aaron
BIGCAV Offline
#7 Posted : Tuesday, 24 January 2012 7:55:33 AM(UTC)
BIGCAV
we were never trully happy with the exhaust, your probably best of posting on my other website www.xfalcon.com and asking there, i know plenty others have done the e series conversion
the stubby mustang headers bent a bit worked, cant remember which one we used but it was from vpw
http://www.vpw.com.au/pr...rCatID=834&PrdGrpID=4353
again this was au motor not e series
couldnt get a fix for the aircon, was considering custom fitting an older compressor but never looked into it, we just never ran aircon
#8 Posted : Tuesday, 24 January 2012 8:05:31 AM(UTC)
You could ask this fellow some questions regarding exhaust and A/C.
http://www.allclassified...display-ad?cid=123230244
