hi there new to this i have a hx sandman van need to know if fitted with rear sway bar or it is sitting on hz rails
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
It will have a HZ chassis number if its on a HZ chassis. HX did not have the sway bar on it standard. That was a HZ RTS thing, which disappeared on WB for some reason.
thanks pal it is a hx chassis butt welds for top brackits dont look right
Late HX chassis (6/77 onwards) looks like a HZ chassis, but shouldn't have rear swaybar mounts. HZ chassis should be thinner steel too so check the steel thickness on a known HX and a known HZ. |
i will have a better look and with the gear stick wood that be in black or crome
