jeff76 Offline
#1 Posted : Monday, 18 June 2012 6:11:45 AM(UTC)
jeff76
hi there new to this i have a hx sandman van need to know if fitted with rear sway bar or it is sitting on hz rails
#2 Posted : Monday, 18 June 2012 7:42:07 AM(UTC)
It will have a HZ chassis number if its on a HZ chassis. HX did not have the sway bar on it standard. That was a HZ RTS thing, which disappeared on WB for some reason.
jeff76 Offline
#3 Posted : Tuesday, 19 June 2012 3:56:59 AM(UTC)
jeff76
thanks pal it is a hx chassis butt welds for top brackits dont look right
#4 Posted : Tuesday, 19 June 2012 5:56:01 AM(UTC)
Late HX chassis (6/77 onwards) looks like a HZ chassis, but shouldn't have rear swaybar mounts. HZ chassis should be thinner steel too so check the steel thickness on a known HX and a known HZ.
jeff76 Offline
#5 Posted : Tuesday, 19 June 2012 7:34:38 AM(UTC)
jeff76
i will have a better look and with the gear stick wood that be in black or crome
