Mick G Offline
#1 Posted : Tuesday, 19 June 2012 5:33:10 AM(UTC)
Mick G
Hello.What do I have to do to put a WB Stato rear into my HZ 1 Tonner.Your help will be greatly appreciated.Thanks,Mick.
Water makes it's own sauce
#2 Posted : Tuesday, 19 June 2012 5:54:24 AM(UTC)
Remove everything and install it into the 1-tonner housing. Then also modify the caliper mounting brackets to move the calipers as if you don't the handbrake mech fouls the leaf springs. You can weld the tonner mounts onto the sedan housing but there is probably no point as you also have to change the front yoke as the tonner yoke accommodates a bigger uni, hence it all has to be setup again anyway.
crowe Offline
#3 Posted : Tuesday, 19 June 2012 7:18:34 AM(UTC)
crowe
I thought the 2.6 ratio is not interchangeableto other housings?
#4 Posted : Tuesday, 19 June 2012 7:40:43 AM(UTC)
It will fit as long as you fit its matching hemisphere.
