I just bought my son a VS, V6 Manual ute, the gear shifter is very sloppy, whats the best way to fix this problem? Thanks
i think late 1997 - 98 99 2000 VS box was Getrag box (better box to drive)
95 96 97 VS was T5
something like that. what year is the ute? |
Its an early 97 if that helps at all. Thanks
I don't know that there's really anything you can do with the sloppy getrag. They were crap from new compared to the earlier T5 (which itself is nowhere near as good as a toyota 5 speed shifter). |
if it is a getrag they have a remote style shifter,the bush in this shifter(plastic) is prone to falling apart causing a lot of slop , part no 92051403
It should be a Getrag gearbox. AFAIK all VSII (June 96 onwards) V6 manual utes had the Getrag box.
The VS V8 utes got the Getrag about a year later (Aug 97) mid-way thru VSII, in line with the release of the VT.
Dr Terry |
Thanks guys, now all I have to do is work out how to get it out, I can see 2 studs going into the top of the box but thats about all I can see. Thanks again for all your help
