#1 Posted : Friday, 6 July 2012 10:22:28 PM(UTC)
the VR V6 has suddenly developed a couple of oil leaks from the engine. not gearbox oil. it has been standing for 2 or 3 days and a fairly large oil patch or 2 underneath.
I did hear there were some oil problems with the early v6s but thought they had been overcome.
where is it most likely the oil leak is coming from?
thanks
#2 Posted : Friday, 6 July 2012 10:28:24 PM(UTC)
If it is leaking while just standing there & not running, it can only be coming from the sump itself. It may be just the sump plug washer, or the sump may be damaged.
#3 Posted : Saturday, 7 July 2012 1:31:14 AM(UTC)
I was warned with the CV8, Cross 8 and also my SR5 V6 Hilux, that I should buy a new fibre washer everytime I changed the oil as they tend to leak randomly if not replaced. As Terry says this might be all it is.
#4 Posted : Saturday, 7 July 2012 8:54:09 AM(UTC)
Thanks I did change the oil a couple of weeks ago. will have another look at it, washers are cheap!
