ccbutton Offline
#1 Posted : Tuesday, 4 September 2012 4:30:36 AM(UTC)
ccbutton
boy and girls
havnt posted in a while but
im having problems with my vs ute!
3.8 L on MGA gas system , going alone nicely driving
flick it to gas run for a sec then dies!
its got a full tank of gas, and i have no idea about gas at all
can some one please give us a hand?
thanks boys and girls :)
#2 Posted : Tuesday, 4 September 2012 6:03:32 AM(UTC)
try letting it idol on petrol and flick it to gas while idling
what can sometimes happen if you flick it over while driving, is the gas safety switch senses a sudden burst of gas and thinks there's a gas leak so it cuts the gas off
ccbutton Offline
#3 Posted : Tuesday, 4 September 2012 6:41:47 AM(UTC)
ccbutton
tryed that
and the motor just cuts out!
#4 Posted : Tuesday, 4 September 2012 7:17:00 AM(UTC)
Turn the car off and switch it to gas, then turn on ignition only . . can you hear the gas flow for a second? You should be able to hear it flow and then 2 seconds later time out. Can you hear it flow?
If no - probably got a power to solenoid problem.
If yes - probably got a problem with the vacuum sensing switch.
This page was generated in 0.022 seconds.
