bigfella-327 Offline
#1 Posted : Sunday, 28 October 2012 1:15:39 AM(UTC)
bigfella-327
G'day All,
Need to replace the diff oil in my HK Monaro, standard 10 Bolt Salisbury LSD. I cannot find the bolt to drain it, only to fill it.
Do I
1/ Have to remove the entire back cover
2/ Is the bottom bolt the drain plug bolt
3/ None of the above - then what?
Any help would be greatly appreciated.
Cheers Al
Premier 350 Offline
#2 Posted : Sunday, 28 October 2012 2:57:11 AM(UTC)
Premier 350
Al,
Try removing the bottom 3 or 4 bolts & loosen other ones on the sides, and gently prise the cover up - about 1/16", tops.
That's the only way I've ever drained GM Salisbury diffs.
Did that on my Skylark, a tiny bit of seepage after a year, but not even enough to drip on the floor ( that's the auto's job- rustprofing my concrete)
#3 Posted : Sunday, 28 October 2012 3:01:13 AM(UTC)
bigfella-327
Hey Man,
Thanks very much for that, that's what I suspected I might be doing.
Al
