Boots n All Offline
#1 Posted : Sunday, 4 November 2012 3:26:19 AM(UTC)
Boots n All
Gday all,
Can anyone help with the id of this old 327 motor i have in the garage?
Engine number stamped = 32741632 then stamped in different profile are T 112131Q or 0 on the end?
Is this a Pontiac or Holden fitted Chev motor ex: what factory?
Cheers Boots....
Cheers Boots....
#2 Posted : Sunday, 4 November 2012 3:48:51 AM(UTC)
Pontiac Parisienne or Chev Impala, 1968 series built here by GMH from 1968 through into the 70's. Car was assembled at Dandenong plant that the engine came from.
Parka Offline
#3 Posted : Monday, 13 January 2014 4:18:23 AM(UTC)
Parka
hey mate how do you know what factory the engine is from??? and can you do the same with the bodys?
#4 Posted : Monday, 13 January 2014 4:27:04 AM(UTC)
Australian built Chevs/Pontiacs/Bedfords etc have a body id plate with simular info to the Holdens/Toranas/Geminis etc.
So if you put the details up they can be interpreted here.
Chevrolet engines were given engine numbers depending on plant, so Brisbane chev engine numbers are between 00001 and 9999, whilst Sydney was assigned 10000 to 39999 and Melbourne 40000 to 73999 etc.
Warren
Parka Offline
#5 Posted : Monday, 13 January 2014 5:00:21 AM(UTC)
Parka
Chevrolet engines were given engine numbers depending on plant, so Brisbane chev engine numbers are between 00001 and 99999, whilst Sydney was assigned 10000 to 39999 and Melbourne 40000 to 74999 etc.
Warren
the body id plate is
BODY 68-16439-12
TRIM 1150-72 A
PAINT 587-1704
it also has a gm plate beside it with L102631???
as for my engine ill have to get back to you,
#6 Posted : Monday, 13 January 2014 5:13:57 PM(UTC)
BODY 68-16439-12 (1968 model, Model type ie 4 door sedan, 12th built)
TRIM 1150-72 A (Silver Mink Metallic with unknown trim) I do not have the info on trim codes for these cars, and as they are unique to Holden built cars it is hard to find this info. But I believe it will be basic red interior of HK type vinyl.
PAINT 587-1704 (Silver Minl Metallic)
#7 Posted : Tuesday, 14 January 2014 12:19:29 AM(UTC)
I think it is the 12th at Elizabeth Warren.
