CrustyHK Offline
#1 Posted : Thursday, 8 November 2012 6:59:37 AM(UTC)
CrustyHK
I'm trying to end up with a very uncluttered dash in the HK ....
Will a later column fit?
#2 Posted : Thursday, 8 November 2012 4:35:55 PM(UTC)
Yes, anything can be made to fit with some modification. But it seems like a lot of work just to lose the wiper/washer knob & ignition barrel of the facia. The dash with be slightly less cluttered, but the column more-so, not much of a gain methinks.
Also a lot of work mechanically to keep safety compliance.
CrustyHK Offline
#3 Posted : Friday, 9 November 2012 3:48:37 AM(UTC)
CrustyHK
Thanks Terry
the idea is to get rid of the existing cluster and fascia completely including the centre fascia and run a set of after market gauges....
Other than using a later Holden column I guess I could use one of the hotrod columns.
What would the compliance issues be for a column swap if it's collapsable as the original is?
