mink 07 Offline
#1 Posted : Tuesday, 4 December 2012 8:06:10 AM(UTC)
mink 07
hi guy's,i was told that hk monaro's have different coloured tailshafts,if thats the case what colour would it be for a 307,glide monaro be.thanks.
#2 Posted : Tuesday, 4 December 2012 6:42:31 PM(UTC)
HK Monaro with 307 and powerglide will be a pink 55.35" tailshaft. These were standard with 2.78 LSD banjo. If it has an optional 10-bolt diff then it'll be a dark green 53.71" tailshaft. If it is a GTS then it'll most likely be the dark green shaft although it was possible to get a HK V8 GTS with banjo.
mink 07 Offline
#3 Posted : Wednesday, 5 December 2012 3:03:10 AM(UTC)
mink 07
thanks for your reply byron,mine is a 307,glide lsd banjo,so i guess it will be a pink tailshaft.geez,of all the colours out there pink.!!do you have any pictures so i could get a rough idea of the shade of pink.thanks in advance.
#4 Posted : Wednesday, 5 December 2012 3:26:15 AM(UTC)
No I don't, the last one I had in original paint is at my mate's place in his HK 307 auto banjo GTS (very early HK GTS when banjos and 5" rims were still standard on GTS). It came from a HG 253 M21 Kingswood sedan (253 M21 banjo also uses the pink tailshaft).
sgo Offline
#5 Posted : Wednesday, 5 December 2012 5:31:16 AM(UTC)
sgo
http://smg.beta.photobuc...t350.jpg.html?sort=3&o=0
Not sure if it's relevant but this is a pic of markings and colour on a HT 350.
sgo Offline
#6 Posted : Wednesday, 5 December 2012 5:33:06 AM(UTC)
sgo
#7 Posted : Wednesday, 5 December 2012 5:38:53 AM(UTC)
^^That is the 2nd type HK GTS327 Voilet shaft. Carried over int0 HT GTS350 manual only and early HG GTS350 manual only.
sgo Offline
#8 Posted : Wednesday, 5 December 2012 6:16:20 AM(UTC)
sgo
Any idea on what the numbers refer to?
mink 07 Offline
#9 Posted : Wednesday, 5 December 2012 8:11:33 AM(UTC)
mink 07
thanks guys,interesting markings on that tailshaft sgo,but i need shade/colour for hk.
