simonbee Offline
#1 Posted : Friday, 18 January 2013 10:52:23 PM(UTC)
simonbee
Hi guys anyone tell me someinfo on the Holley carb doublepumper not sure what size it is and if its ok to put on my 350 Chev its a 4777-2
are these good carbys,,,,
#2 Posted : Friday, 18 January 2013 11:58:42 PM(UTC)
I believe a 4777-2 Holley is a 650 DP.
Not a bad carby, but what's wrong with a Quadrajet.
simonbee Offline
#3 Posted : Saturday, 19 January 2013 12:55:09 AM(UTC)
simonbee
Hi Dr Terry yes i thought that was the case thanks, the Quadrajet is a great carby which i dont have so i will have to make do what i have.
detective Offline
#4 Posted : Saturday, 19 January 2013 2:22:18 AM(UTC)
detective
hi simonbee .. i guess it depends on your application but you might find with the Holley 650 that your engine may be a little under carburetted and possibly not happy without a bootful on the throttle most of the time...
...went down this road as a young bloke with my own GTS350 and quickly changed back to the 780 CFM that was on the car when i bought it...
...the Quadrajet was rated at about 750 CFM for the 350's and are still a very good carby to consider....cheers mate
Simmo Offline
#5 Posted : Monday, 21 January 2013 7:41:47 AM(UTC)
Simmo
But a quadrajet airvalve that dampens then sudden opening of the secondaries where as a double pumper doesnt, thus when selecting a carb for any given engine a double pumper should be smaller than an airvalve or vacume secondary equipped carb.
Is the manifold drilled for squarebore, spreadbore or both.
detective Offline
#6 Posted : Monday, 21 January 2013 7:56:42 AM(UTC)
detective
...thats pretty much the guts of it Simmo .. the Holley 780 on my own car is a single pump, vacuum secondary...set up for the TH 400 and was/is a good and proper fit, whereby the double pump mechanical secondaries were always a better fit for a big cube HP manual...
...pretty sure this arrangement on mine is set upon a spread bore inlet manifold...(factory HQ GTS350)
