zl296 Offline
#1 Posted : Saturday, 16 March 2013 6:23:42 AM(UTC)
zl296
hi all,have a v.s series 2 commodore ute..
its manual,go to start it,goes then stops...has fuel....
can hear the fuel pump going.
do this about 10 times,then starts ok?
any idea,s....
castellan Offline
#2 Posted : Saturday, 16 March 2013 9:04:24 AM(UTC)
castellan
crank angle sensor. V6 ?
More information.
zl296 Offline
#3 Posted : Saturday, 16 March 2013 9:35:35 AM(UTC)
zl296
yes is a v/6
once started you can turn off starts ok,drive good no miss.
next day same again cranks good,but starts then stops.?
#4 Posted : Saturday, 16 March 2013 7:55:28 PM(UTC)
Could be low fuel pressure from a tired pump - it needs time to build pressure, and the initial burst when you turn the key may not be enough. You can diagnose this easily by manually bridging the fuel pump relay terminals with a paperclip for 20-30 seconds or so before you try to cold-start the car. If it starts straight away, then it's a tired pump.
Have you tried bridging out the diagnostic terminals in the OBD plug & counting the flashes of the check engine light? The ECM has possibly stored a fault code that will pinpoint the problem for you.
zl296 Offline
#5 Posted : Saturday, 16 March 2013 8:29:43 PM(UTC)
zl296
thanks mick will try....
zl296 Offline
#6 Posted : Sunday, 17 March 2013 3:25:19 AM(UTC)
zl296
weak fuel pump.....
thanks...
