sgo Offline
#1 Posted : Wednesday, 17 April 2013 4:02:33 AM(UTC)
sgo
Re. HT 350 GTS:
I assume this switch is in the "on postition" as shown in this pic?
When in neutral gear; is the switch moved to A or B direction ????
Edited by user Wednesday, 17 April 2013 4:04:29 AM(UTC)  | Reason: Not specified
#2 Posted : Wednesday, 17 April 2013 4:32:56 AM(UTC)
Mount the switch with the side cover bolts, then run a rod from the reverse lever on the side of the box to the switch. (both have holes for the rod, as shown on the switch above.)
Warren
sgo Offline
#3 Posted : Wednesday, 17 April 2013 6:34:14 AM(UTC)
sgo
Thanks for the update Warren.
At the moment the car is in bits and not handy, are you able to help with the above question?
cheers, sgo.
#4 Posted : Wednesday, 17 April 2013 6:53:56 AM(UTC)
I don't know the answer, but 2 minutes with a multi-meter & I could give it to you.
As they say in the classics, "it's not rocket science".
sgo Offline
#5 Posted : Wednesday, 17 April 2013 8:43:18 AM(UTC)
sgo
I've got the multi-meter but no switch to try it on :)
I don't have switch or gear-box handy.
I know the switch is "on" when at rest as in the pic, but which way does the arm move when the gear-shift is moved to neutral?
I suppose if I knew if the switch was mounted fore or aft of the gear-box reverse lever that would answer my question?
