sgo Offline
#1 Posted : Wednesday, 17 April 2013 4:02:33 AM(UTC)
sgo
Re. HT 350 GTS:
I assume this switch is in the "on postition" as shown in this pic?
When in neutral gear; is the switch moved to A or B direction ????
Edited by user Wednesday, 17 April 2013 4:04:29 AM(UTC)  | Reason: Not specified
#2 Posted : Wednesday, 17 April 2013 4:32:56 AM(UTC)
Mount the switch with the side cover bolts, then run a rod from the reverse lever on the side of the box to the switch. (both have holes for the rod, as shown on the switch above.)
Warren
sgo Offline
#3 Posted : Wednesday, 17 April 2013 6:34:14 AM(UTC)
sgo
Thanks for the update Warren.
At the moment the car is in bits and not handy, are you able to help with the above question?
cheers, sgo.
Dr Terry Online
#4 Posted : Wednesday, 17 April 2013 6:53:56 AM(UTC)
I don't know the answer, but 2 minutes with a multi-meter & I could give it to you.
As they say in the classics, "it's not rocket science".
sgo Offline
#5 Posted : Wednesday, 17 April 2013 8:43:18 AM(UTC)
sgo
I've got the multi-meter but no switch to try it on :)
I don't have switch or gear-box handy.
I know the switch is "on" when at rest as in the pic, but which way does the arm move when the gear-shift is moved to neutral?
I suppose if I knew if the switch was mounted fore or aft of the gear-box reverse lever that would answer my question?
