David 67HR Offline
#1 Posted : Wednesday, 15 May 2013 7:51:41 PM(UTC)
David 67HR
What model did the 179HP block come out in, in Holden engine codes it says 186k is a 186HP block is this correct?
#2 Posted : Wednesday, 15 May 2013 7:59:35 PM(UTC)
179 with HP on it were EH only. The HP casting was replaced by 179 late in EH from memory. I think these have engine numbers starting with M.
No such thing as a 186 with HP on the side, they are all 186 cast. 186K is either an X2 or a 186S engine, there is a breakpoint number in the parts catalogues that tells you which it is eitehr side of that number.
Utility8 Offline
#3 Posted : Wednesday, 15 May 2013 9:12:04 PM(UTC)
Utility8
& HD.
Edited by user Wednesday, 15 May 2013 9:40:05 PM(UTC)  | Reason: Not specified
utility8
David 67HR Offline
#4 Posted : Wednesday, 15 May 2013 9:54:53 PM(UTC)
David 67HR
You are the Man Doctor Terry, I understand about the 186K engines, I have one form a 186S
Guest (5)
