Jul71-Oct74 Offline
#1 Posted : Sunday, 30 June 2013 5:23:56 PM(UTC)
Jul71-Oct74
Hi All
Took the HQ for a drive this afternoon and noticed that the heater fan is working,but on both Hi and Lo settings it is spinning a lot slower than usual. I am thinking that somewhere in the circuit I have an increase in resistance or alternatively the motor is beginning to fail.
Can anyone give me some tips on what to check and what is the most likely cause of the problem.
Thanks for any advice
Richard
Premier 350 Offline
#2 Posted : Sunday, 30 June 2013 7:10:30 PM(UTC)
Premier 350
Motor bushes need lube? Maybe. I'd be checking the voltage at the fan
on both speeds first.
Might also pay to check voltage going into & out from the switch, to
eliminate that as the problem.
Dunno if its possible- could you disconnect the fan from its wiring &
try 12V direct from the battery?
Would also pay to remove the fan and see if it spins freely. Is it making any odd noises?
Chris
Jul71-Oct74 Offline
#3 Posted : Wednesday, 3 July 2013 5:43:24 PM(UTC)
Jul71-Oct74
Hi Chris
No odd noises, just spinning slower than normal.
Premier 350 Offline
#4 Posted : Thursday, 4 July 2013 4:51:49 AM(UTC)
Premier 350
Go for a voltage check would be my next step.
Chris
Balfizar Offline
#5 Posted : Friday, 5 July 2013 4:53:48 AM(UTC)
Balfizar
Was thanked: 16 time(s) in 16 post(s)
Originally posted by Premier 350
Motor bushes need lube? Maybe. I'd be checking the voltage at the fan on both speeds first.
Chris
Never lubricate brushes, only check length, spring tension, not binding in slides.
the rest is good!
Balfizar
Premier 350 Offline
#6 Posted : Saturday, 6 July 2013 6:28:10 AM(UTC)
Premier 350
I said "bushes" not "brushes" :)
Chris
