blameyone Offline
#1 Posted : Friday, 9 August 2013 1:15:26 PM(UTC)
blameyone
Can some one help me with my V6 VY random engine cooling behaviour. It's driven daily by my wife who's pretty gentle with our commodore, but a couple of weeks back it lost all water and naturally got very hot as a result. My 1st thoughts were well there's obviously a leak in the system somewhere, radiator or a hose or gasket or something like that. Well we let it cool off and filled it up with water to check where, but no obvious leaks so for a day or two we kept the water up to it making sure it did'nt run out of water and after a day or two driving and losing water, the problem disappeared, so all good we continued the daily driving for a week untill today all started losing water again. Why the stop start getting hot and losing water. Would it be the thermostat playing up ?....Jack
Utility8 Offline
#2 Posted : Friday, 9 August 2013 7:13:53 PM(UTC)
Utility8
As with any motor, there are many places for water to leak from or disappear into.
Have the cooling system pressure tested, if possible, while both cold & hot.
Also, have the cooling system tested for exhaust gasses.
Thermostat might be playing up, but wont account for water loss.
utility8
JBM Offline
#3 Posted : Friday, 9 August 2013 7:47:54 PM(UTC)
JBM
Try not to use tap water, it's ok for older cast iron blocks and heads but Alloy doesn't like it at all.
James
#4 Posted : Friday, 9 August 2013 8:24:22 PM(UTC)
James
Yes, even though the block & heads are cast iron, Commodores have a lot of alloy bits including radiator core, water pump, timing cover, inlet manifold etc. etc.
Coolant/inhibitor quality & mix is very important.
Most likely causes of coolant loss in VS-VY V6s is a leaky water pump or heater valve.
