Mr Sir Offline
#1 Posted : Sunday, 11 August 2013 4:58:03 AM(UTC)
Mr Sir
Is the rear window on a HQ-WB Panel van the same as the style side ute of the same model range. I measured up a window that I believe that I have removed from a Toner and it measures longer at the base
#2 Posted : Sunday, 11 August 2013 8:19:01 PM(UTC)
HQ-WB Ute & One-Tonner have the same rear glass.
Panel van rear glass is different, but is the same as HK/T/G van & possibly HD/HR van ??
Style side ute, WTF !!!
HGV8 Offline
#3 Posted : Monday, 12 August 2013 5:54:04 AM(UTC)
HGV8
Was thanked: 11 time(s) in 10 post(s)
Havn't heard that for years, decades more like it. "Style side" is an old 1930's to 60's way of describing a coupe ute as opposed to a tray style ute.
Edited by user Monday, 12 August 2013 5:56:52 AM(UTC)  | Reason: Not specified
j.williams
#4 Posted : Monday, 12 August 2013 5:38:15 PM(UTC)
Haven't heard it for years? Every second HQ-WB ute on eBay are called "style side" now. Grrr. Why people now think Australian utes have the same terminology as American pickup boxes is bizarre.
#5 Posted : Monday, 12 August 2013 6:15:43 PM(UTC)
Maybe, like me, HGV8 hasn't bothered with ebay for years.
I though the only reason you would need to use the term 'style side' is to differentiate it from a 'step side' which are quite rare in Australia.
Here we have Utes & One-Tonners, no confusion there.
#6 Posted : Tuesday, 13 August 2013 12:42:23 AM(UTC)
GMH called the C20 and K20 with a pickup box a "Fleetside", or at least the optional ute box was called a "Fleetside Pickup Box", possibly because Ford used the Styleside term for F100/F250?
Mr Sir Offline
#7 Posted : Friday, 16 August 2013 8:55:30 PM(UTC)
Mr Sir
When looking at the van window rubber listings on Rares spares listings they do go through a lot of the earlier models including the hq's to wb's but none are listed to suit van AND COUPE UTILITY's (IS THAT the correct term to say FOR NOW???? , s*** I am glad I did not call a hz GTS a Monaro!!!!; P) of the same model to say that that the glass is one and the same. I just want to replace my glass as it is badly scratched, a bubble window seems an easier option cheers Ms
#8 Posted : Friday, 16 August 2013 9:36:55 PM(UTC)
As Dr Terry says ute/tonner glass is different to van hence the rubbers won't be the same for both.
#9 Posted : Friday, 16 August 2013 9:39:07 PM(UTC)
It's just a UTE (or utility), you don't hear too many bothering with the name 'coupe utility'.
What we are joking about is the unnecessary American Ford term 'style side'
All that aside, I think that you missed my comment that the ute & One-Tonner rear glass is DIFFERENT to the panel van, so any rubber will also be different.
#10 Posted : Friday, 16 August 2013 9:47:50 PM(UTC)
I didn't think that we were that picky around here.
To my mind the HZ GTS is a Monaro just by association, just as an HX LE Coupe is, but Holden never built a 'style side' anything.
