HKM068 Offline
#1 Posted : Sunday, 11 August 2013 4:14:11 PM(UTC)
HKM068
All
The speedo in my HK appears to be slightly inaccurate, reading about 10-15% low. The car was originally a six but has a 307 and Powerglide from a Brougham.
Before I start dismantling, is there anything specific to check. The cable also appears to be kinked somewhere (bouncing needle and associated scraping sound) so that will need replacing as well.
Thanks in advance
HKM
Bluez Offline
#2 Posted : Sunday, 11 August 2013 6:27:33 PM(UTC)
Bluez
Did the Speedo cable and Speedo gear come from the brougham as well? If it did, possibly the diff ratios were different from yours, meaning Speedo gear is not correct.
Jesse Jesse Jesse, you've not got a sense of humour!
#3 Posted : Sunday, 11 August 2013 8:22:57 PM(UTC)
If the speedo gears are also from the Brougham they match a 2.78 rear axle & 6.95 x 14 tyres.
You probably have a lower diff & different tyres, so some experimenting with different speedo gears will be needed.
HKM068 Offline
#4 Posted : Monday, 12 August 2013 7:03:14 AM(UTC)
HKM068
Thanks, Gents.
The powerglide and diff are from the Brougham but I suspect that the speedo gear is from the original gearbox. eBay here I come!!
HKM
80569K Offline
#5 Posted : Tuesday, 13 August 2013 2:19:04 AM(UTC)
80569K
