81837 Offline
#1 Posted : Sunday, 6 October 2013 4:44:50 AM(UTC)
81837
I've just looked at a mates bike engine after the timing chain let go, lots of bent valves and smashed pistons. Why does this not happen to the old red six? They just stop! Is there enough clearance at TDC to allow an open valve?
Regards
peter_flane Offline
#2 Posted : Sunday, 6 October 2013 9:50:29 AM(UTC)
peter_flane
You got it.
Non interference engine. The motor just stops producing power, but still turns. Replace the stripped gear and it will run again.
The HKTG Garage Offline
#3 Posted : Tuesday, 8 October 2013 6:06:52 AM(UTC)
The HKTG Garage
Yep, mine went doing 110 kph last year. I still use the same 186 as a daily. It hasn't seemed to of affected anything else.
#4 Posted : Tuesday, 8 October 2013 6:49:04 AM(UTC)
I stripped a gear at 100k's, it was just like I turned the key off
I towed the car home and replaced the gear that afternoon, I didn't even take the cam out!
At the time (about 13 years ago) the new aluminum gear and timing case gasket was $40
