David 67HR Offline
#1 Posted : Sunday, 4 May 2014 3:44:40 AM(UTC)
David 67HR
Can you tell me what is this code for HR trim please
1223 E59
#2 Posted : Sunday, 4 May 2014 4:48:57 AM(UTC)
Hi David
1223 = Cordovan with a Grecian White roof
E59 = COPRA & VALSAND FAWN INTERIOR TRIM (Special Sedan)
#3 Posted : Sunday, 4 May 2014 6:03:04 AM(UTC)
David, you could probably benefit from the purchase of one of these;-
http://jadlawpublishing....oduct=holdens-black-book
It is Warren Turnbull's new book & has all the plate info you need.
David 67HR Offline
#4 Posted : Sunday, 4 May 2014 7:03:37 AM(UTC)
David 67HR
Thanks Dr Terry,
1223-E59 is the Trim number....Paint Cordovan
10317 is the Paint number Cordovan
Is that normal to list like that.
Thanks for info on the Book
bazza30555 Offline
#5 Posted : Sunday, 4 May 2014 10:59:11 AM(UTC)
bazza30555
Hi Terry, where about's in the book is the reference to 1223 being cordovan with Grecian white. Cheers Bazza
#6 Posted : Sunday, 4 May 2014 6:43:50 PM(UTC)
Unfortunately the 1223 won't be here, however all of the paint codes & interior trim numbers are there.
You can glean the Cordovan/Grecian combination be referencing the 10317/9562 numbers from the PAINT & TOP info on the body plate.
#7 Posted : Sunday, 4 May 2014 6:51:46 PM(UTC)
Originally posted by David 67HR
Thanks Dr Terry,
Yes, the 1223 is the GM-H code for that paint combination. Having the entire exterior (& interior) description all in one line makes life easy when processing sales orders.
It is easier than using the Dulux paint numbers. Those numbers are stamped on the body plate for use by panelbeaters when refinishing.
David 67HR Offline
#8 Posted : Friday, 30 May 2014 7:36:00 AM(UTC)
David 67HR
DR Terry, is this for a Station Wagon
HR229AR
882-E64
585-8703
Edited by user Friday, 30 May 2014 7:44:44 AM(UTC)  | Reason: Not specified
Mr.Jones Offline
#9 Posted : Friday, 30 May 2014 4:54:54 PM(UTC)
Mr.Jones
882 is Grecian White over Sandown Fawn
E64 is Copra & Valsand Fawn from a Special Station Sedan
Edited by user Friday, 30 May 2014 4:57:23 PM(UTC)  | Reason: Not specified
Voltaire
#10 Posted : Friday, 30 May 2014 6:32:16 PM(UTC)
HR229AR
882-E64
585-8703
Mr Jones has already deciphered the codess, but the numbers that you've posted from the body ID plate are missing one line of info. This is a perfect example of where the first part of the TRIM number is of use.
You've only listed one paint number, while there should be two. The second being paint number of the Grecian White roof (listed as TOP).
This car is 2-tone (Grecian over Sandown Fawn) & the 882 is GM-H's code for that. Had it been Sandown Fawn all over (single tone) the first part of the TRIM number would have been 1135.
I almost forgot, yes David 229 is a Special Station sedan (wagon).
David 67HR Offline
#11 Posted : Saturday, 31 May 2014 3:28:24 AM(UTC)
David 67HR
Thanks for the Info Dr Terry and Mr Jones
David 67HR Offline
#12 Posted : Saturday, 31 May 2014 9:06:26 PM(UTC)
David 67HR
More codes to unravel
875-E55
585-6568
565-9562
Mr.Jones Offline
#13 Posted : Sunday, 1 June 2014 2:18:21 AM(UTC)
Mr.Jones
875 is Grecian White over Pemberton Grey
E55 is Dante & Mephisto Red in a Special Sedan
The 1st paint code should be 8568
Do you have a pic of the car it's from I haven't got one for Pemberton and would like to add to my O/H shed?
Voltaire
