#1 Posted : Thursday, 22 May 2014 4:39:53 AM(UTC)
the daughters 99 astra has developed and oil leak from apparently the front (crank pulley) end of motor.
can't see any obvious source.
what is the most usual source?
thanks
petaus Offline
#2 Posted : Friday, 23 May 2014 6:32:44 AM(UTC)
petaus
Hi, John usally its the oil pump/crank seal or one of the cam seal, I would degress wash down run it and confirm then strip the timing belt covers off, I had a mitsubihi lancer that was leaking same area suspected the crank/oil pump seal when I stripped it I could not see where it originated so I wash it down refitted the balancer ran it with out the cover it ran for five minutes befor itstarted to leak.
if it is the crank/pump seal becarefull u get the correct size seal a couple different sizes from memory and the nose of the seal area on the crank has a sharp edge carefull not to cut the seal.
fit a full timing belt kit while u are there.
pete.
#3 Posted : Monday, 2 June 2014 8:34:09 AM(UTC)
petaus thanks for the info, will tackle it when rain stops.
regards,
