Joined: 2/02/2009(UTC) Posts: 567  ![Australia Australia]() Location: On a build over WWII airfield. Got the .50 cal cases from my driveway to prove it Thanks: 32 times Was thanked: 9 time(s) in 9 post(s)
Any idea of what its worth? Chev 350, 4 bolt. Complete & running.Been stored for 5 years, fired it up yesterday. Holley vac secondary carb (not sure of size) GM HEI distributor Performer RPM intake. Genie extractors- a bit rusty but usable for a while yet. Speed pro cam- Corvette 350 HP grind. Geared starter motor. Corvette alloy rocker covers. Comes with high mount alt & a power steering pump. High volume oil pump. Would have 40,000 miles on it. Comes with a TH 400.
The bad. Needs an engine mount. A section of the block around the outer started bolt has been broken away. Plenty of depth for the bolt left and it never gave any agro. Also available seperatly are a HQ 350 crossmember. 2 1/2" dual system to suit HQ-Z wagon. Surface rust but usable. HQ 4 row manual radiator. I won't get anything like I've spent on it, with cheap crate motors around, equally I don't want to sell it for nothing.
Attn camry drivers. The accelerator is the skinny pedal on the right. |
Thanks: 1 times Was thanked: 629 time(s) in 592 post(s)
Hard to say Chris. What heads are on it?
If you don't sell the radiator with it i'd be interested init for my HK. |
Nothing special. Casting # are 3886336 if that helps. Was told they were early-mid 70s smog heads.
I'm outer Nth side Brisbane based. Cheers,
Chris |
Update. Carby is 600 CFM,vac secondaries, electric choke. Cam is hydraulic.
Chrome timing cover & alt mount & aircleaner. Surface rust on the lid. |
I may be in Brisbane very soon for a day or so. I can have a look if you like, may be able to "sell" it as such for him to a few mates. I'd be interested in the radiator too. |
Byron, I tried to send you an email from your profile, no joy. Please check my profile & you'll see my gmail addy. Best way to contact me on this forum.
Chris |
It isn't working for me either, must be busted. WIll try another way. |
Message received Byron. Look forward to hearing from you.
Chris |
