Premier 350 Offline
#1 Posted : Thursday, 28 August 2014 6:07:25 PM(UTC)
Premier 350
Any idea of what its worth?
Chev 350, 4 bolt. Complete & running.Been stored for 5 years, fired it up yesterday.
Holley vac secondary carb (not sure of size)
GM HEI distributor
Performer RPM intake.
Genie extractors- a bit rusty but usable for a while yet.
Speed pro cam- Corvette 350 HP grind.
Geared starter motor.
Corvette alloy rocker covers.
Comes with high mount alt & a power steering pump.
High volume oil pump.
Would have 40,000 miles on it.
Comes with a TH 400.
The bad. Needs an engine mount.
A section of the block around the outer started bolt has been broken away. Plenty of depth for the bolt left and it never gave any agro.
Also available seperatly are a HQ 350 crossmember.
2 1/2" dual system to suit HQ-Z wagon. Surface rust but usable.
HQ 4 row manual radiator.
I won't get anything like I've spent on it, with cheap crate motors
around, equally I don't want to sell it for nothing.
#2 Posted : Friday, 29 August 2014 12:06:39 AM(UTC)
Hard to say Chris. What heads are on it?
If you don't sell the radiator with it i'd be interested init for my HK.
Premier 350 Offline
#3 Posted : Friday, 29 August 2014 1:17:18 AM(UTC)
Premier 350
Nothing special. Casting # are 3886336 if that helps.
Was told they were early-mid 70s smog heads.
I'm outer Nth side Brisbane based.
Chris
Premier 350 Offline
#4 Posted : Friday, 29 August 2014 1:38:13 AM(UTC)
Premier 350
Update. Carby is 600 CFM,vac secondaries, electric choke.
Cam is hydraulic.
Chrome timing cover & alt mount & aircleaner. Surface rust on the lid.
#5 Posted : Friday, 29 August 2014 1:56:14 AM(UTC)
I may be in Brisbane very soon for a day or so. I can have a look if you like, may be able to "sell" it as such for him to a few mates. I'd be interested in the radiator too.
Premier 350 Offline
#6 Posted : Friday, 29 August 2014 2:06:42 AM(UTC)
Premier 350
Byron, I tried to send you an email from your profile, no joy. Please check my profile & you'll see my gmail addy.
Best way to contact me on this forum.
Chris
#7 Posted : Friday, 29 August 2014 4:27:50 AM(UTC)
It isn't working for me either, must be busted. WIll try another way.
Premier 350 Offline
#8 Posted : Tuesday, 2 September 2014 12:12:37 AM(UTC)
Premier 350
Message received Byron. Look forward to hearing from you.
Chris
