Gerard Offline
#1 Posted : Wednesday, 21 January 2015 9:00:59 AM(UTC)
Gerard
I am renewing these pipes on my car and I am not able to buy the correct size stone guard material for either of these pipes. I have a piece that is a reasonable fit for the brake pipe but nothing close for the fuel pipe. Would appreciate to know if the correct size material is still available for either of these pipes and if so who sells it.
#2 Posted : Wednesday, 21 January 2015 6:19:24 PM(UTC)
Are you talking about what looks like a spring wound around the brake & fuel pipes ?
If so, I stock it for 3/16" & 1/4" pipe, but not for 5/16", which is what GM-H use for their fuel lines.
Gerard Offline
#3 Posted : Thursday, 22 January 2015 1:37:11 AM(UTC)
Gerard
Dr Terry, thanks for the reply and that is the parts I am talking about. Not sure what there really called. I will get by with the brake pipe piece which is already installed on that new pipe, but would still be interested if anyone has any details of where to get the correct material for the 5/16 fuel pipe.
The details of the fuel pipe as best as I can determine as follows.
Imperial -
Fuel pipe: 5/16" or 0.3" - Stone guard/spring - inside diameter 0.35" - outside diameter 0.45"
Metric -
Fuel pipe 8.0 mm - Stone guard/spring - inside diameter 9.5mm - outside diameter 11.0mm. Appreciate any details given.
gm5735 Offline
#4 Posted : Thursday, 22 January 2015 4:08:13 AM(UTC)
gm5735
I just had some fuel lines made for my car. Try Dave at Bellarine Classic Autos, as he has a supplier with the correct spring. I'm not sure if he will sell you just the spring, but it couldn't hurt to ask.
(Be patient, as he is difficult to catch sometimes)
Gerard Offline
#5 Posted : Thursday, 22 January 2015 6:43:40 AM(UTC)
Gerard
gm5735 - Thanks for these details, will contact Dave and see how it goes.
gm5735 Offline
#6 Posted : Friday, 23 January 2015 1:09:54 AM(UTC)
gm5735
Hi Gerard,
I happened to be speaking to Dave today on an unrelated matter, and asked him about your issue. He thinks it should be fine to supply just the spring. His mobile number is 0412 109 239.
Gerard Offline
#7 Posted : Friday, 23 January 2015 7:32:45 PM(UTC)
Gerard
gm5735
Thanks for the contact, have spoken to Dave and he will check on supplying this material - Regards Gerard
