WAHK80737 Offline
#1 Posted : Tuesday, 28 July 2015 10:38:08 AM(UTC)
WAHK80737
I have a Hk GTS. the plastic trim that sits behind the wood grain insert on the glove box lid is cracked all the way through so I need to replace it. What I'd like help with is if this part is unique to the hK GTS or if I could use one from a Premier, kingswood or regular Monaro? are the holes for attaching the various badges and insert trim all the same?
thanks, Simon
#2 Posted : Tuesday, 28 July 2015 4:39:38 PM(UTC)
AFAIK the Premier and Brougham ones are identical to GTS, even the badge holes. Not sure about the Monaro/Kingswood one, these are textured from memory and may not take the Premier/GTS/Brougham insert. I have NOS examples of most of them but would have to go looking to find them.
#3 Posted : Tuesday, 28 July 2015 5:40:45 PM(UTC)
Agreed. I believe that the Monaro GTS, Premier & Brougham items are the same for HK.
The Kingswood & Monaro have a one-piece plastic casting which includes the badge itself, so they could possibly be used if the badge script was ground off. It may be of a different thickness though.
Belmonts do not have a glovebox lid trim.
WAHK80737 Offline
#4 Posted : Tuesday, 28 July 2015 9:11:12 PM(UTC)
WAHK80737
Awesome - thanks very much for the info. Simon.
