RussVRute Offline
#1 Posted : Sunday, 29 May 2005 5:43:07 AM(UTC)
RussVRute
G'day All,
My indicators dont cancel after a right turn, is that something that is common and if so is it easy to fix? I havent taken a steering wheel off for nearly 20 years, what do I need to look for? Thanks .
Russ
crowe Offline
#2 Posted : Sunday, 29 May 2005 6:13:47 AM(UTC)
crowe
May have a broken spring or plastic tab. You have to take the wheel off to find out. Hint- lossen the steering wheel nut a couple of turns as you have to wobble/ flex the steering wheel to free it. Mark the splines as so you put it back in the same spot.
#3 Posted : Sunday, 29 May 2005 7:40:12 PM(UTC)
Normally when I've found this it's one of the cancelling springs/wire loop missing or someone has fitted the horn and cancelling mech onto a sports wheel in the wrong place. If the wheel won't remove as Crowe says you may need a puller.
jabba Offline
#4 Posted : Wednesday, 1 June 2005 7:18:52 PM(UTC)
jabba
Or failing that, a helmet to prevent steering wheel leaving imprint in forehead...
Tour Director Offline
#5 Posted : Friday, 3 June 2005 5:09:16 AM(UTC)
Tour Director
The indicator switch (located behind the steering wheel) has a plastic component and a couple of springs.Once you have the wheel off you can easily see what is broken or not. You can get replacement springs SC1002 from Rares
This page was generated in 0.100 seconds.
