G'day All, My indicators dont cancel after a right turn, is that something that is common and if so is it easy to fix? I havent taken a steering wheel off for nearly 20 years, what do I need to look for? Thanks . Russ
Joined: 3/03/2005(UTC) Posts: 287 ![Australia Australia]()
May have a broken spring or plastic tab. You have to take the wheel off to find out. Hint- lossen the steering wheel nut a couple of turns as you have to wobble/ flex the steering wheel to free it. Mark the splines as so you put it back in the same spot.
Thanks: 1 times Was thanked: 635 time(s) in 597 post(s)
Normally when I've found this it's one of the cancelling springs/wire loop missing or someone has fitted the horn and cancelling mech onto a sports wheel in the wrong place. If the wheel won't remove as Crowe says you may need a puller. |
Or failing that, a helmet to prevent steering wheel leaving imprint in forehead...
__________________________________________ Keep the shiny side up, and the greasy side down. |
Joined: 2/03/2005(UTC) Posts: 451  ![Australia Australia]() Was thanked: 15 time(s) in 14 post(s)
The indicator switch (located behind the steering wheel) has a plastic component and a couple of springs.Once you have the wheel off you can easily see what is broken or not. You can get replacement springs SC1002 from Rares
