RussVRute Offline
#1 Posted : Sunday, 29 May 2005 5:43:07 AM(UTC)
RussVRute
G'day All,
My indicators dont cancel after a right turn, is that something that is common and if so is it easy to fix? I havent taken a steering wheel off for nearly 20 years, what do I need to look for? Thanks .
Russ
crowe Offline
#2 Posted : Sunday, 29 May 2005 6:13:47 AM(UTC)
crowe
Groups:: Registered
May have a broken spring or plastic tab. You have to take the wheel off to find out. Hint- lossen the steering wheel nut a couple of turns as you have to wobble/ flex the steering wheel to free it. Mark the splines as so you put it back in the same spot.
#3 Posted : Sunday, 29 May 2005 7:40:12 PM(UTC)
Normally when I've found this it's one of the cancelling springs/wire loop missing or someone has fitted the horn and cancelling mech onto a sports wheel in the wrong place. If the wheel won't remove as Crowe says you may need a puller.
jabba Offline
#4 Posted : Wednesday, 1 June 2005 7:18:52 PM(UTC)
jabba
Or failing that, a helmet to prevent steering wheel leaving imprint in forehead...
Tour Director Offline
#5 Posted : Friday, 3 June 2005 5:09:16 AM(UTC)
Tour Director
The indicator switch (located behind the steering wheel) has a plastic component and a couple of springs.Once you have the wheel off you can easily see what is broken or not. You can get replacement springs SC1002 from Rares
Guest (5)
